How much is my engine worth approximately
Old Jun 15, 2012 | 07:31 AM
Roverchick's Avatar
Question How much is my engine worth approximately
Guys I found this awesome LR mechanic in Ohio. I just did an engine swap as I has a valve cover leak and I let the oil get too low. The LR mechanic is interested in my old engine as he rebuilds them and I was wondering what is an approximate fair price for it. It is a 2003 LR Discovery II with 115K on it. It was serviced regularly by the dealership until about a year and a half ago so for the most part it is in pretty good nick. Thanks guys for any input.
Old Jun 15, 2012 | 07:43 AM
drowssap's Avatar
"I just did an engine swap as I has a valve cover leak and I let the oil get too low."
so the motor is seized or you just had the most espensive valve cover gasket replacement in history?
Old Jun 15, 2012 | 07:47 AM
Why would you let your engine leak oil, and the smell of burned oil is very noticable? I would suggest you start maintaining your Disco like most all of us do and check your fluid levels once a month, along with tightening 4 bolts at every oil change would have saved you $thousand.
Old Jun 15, 2012 | 08:10 AM
Roverchick's Avatar
The engine did not seize but it started knocking
Old Jun 15, 2012 | 08:12 AM
Roverchick's Avatar
Thanks for the tip on tightening the bolts. I will make sure I figure out how to do that. Yes I do agree that i made a mistake but I am single mom who does not know much about cars and I am trying to learn. Your information has helped me a lot.
Old Jun 15, 2012 | 08:13 AM
Roverchick's Avatar
Just an FYI the dealership maintained my truck up until about a year and a half ago when I got laid off and so I am only just learning what it takes to maintain it. This is why I joined so that I can teach myself.
Old Jun 15, 2012 | 08:30 AM
drowssap's Avatar
what did he offer you?
Old Jun 15, 2012 | 08:33 AM
Roverchick's Avatar
Said we will talk when I come in to do some repairs on my truck so nothing yet but since I am a novice I wanted to know what a reasonable offer is. Right now I have no clue.
Old Jun 15, 2012 | 11:41 AM
jafir's Avatar
Depends on the condition of the stuff. Well known and trusted people get about $500 for a 4.6L crankshaft, rods, and pistons for people wanting to turn their 4.0 into a 4.6L. But everything would probably have to be usable. Since you are not in the business of selling parts, I wouldn't expect to get that much. Perhaps for the complete engine, with block, heads, and everything, if you can get close to that, you'd be doing really well.
A good, well-running 4.0 will sell for close to $2000 in used condition. (again, from the trusted re-sellers, who will stand behind their parts)
Old Jun 15, 2012 | 11:43 AM
jafir's Avatar
If it were me... I'd keep the engine, and buy a harbor freight engine stand and rebuild it slowly in my garage. I'd rather have a nice core that just has a little rod knock or lifter noise than a boat anchor that I or someone else overheated.
