How much time should I budget to replace all the exhaust gaskets?
Old Sep 4, 2020 | 09:09 PM
Brandon318's Avatar
Default How much time should I budget to replace all the exhaust gaskets?
I know I need to replace the manifold gaskets, and figured I might as well do the Y pipe. Just trying to anticipate the amount of time it might take... a few hours? All day?
Old Sep 4, 2020 | 09:22 PM
All depends on the bolts. If they come loose the manifolds are not bad to do. Y pipe can be a pain but also hinges on the bolts. Things start snapping and needing drilled and the game changes
Old Sep 4, 2020 | 09:38 PM
Brandon318's Avatar
Noted. Let's assume after soaking in PB for a few days beforehand and they all come off... couple hours?
Old Sep 4, 2020 | 09:50 PM
Boostle's Avatar
Nothing ever goes as planned so put aside two days lol
Old Sep 4, 2020 | 10:41 PM
Best4x4's Avatar
Also if you have SAI it's a little tougher, and the drivers side has the steering shaft in the way which sometimes can be in the way or hard to work around.
Old Sep 5, 2020 | 12:48 AM
Richard Gallant's Avatar
Budget a day, the manifold to head bolts are the one you do not want to snap. The Y pipe is painful if you snap studs but pretty easy to fix. Just take you time and do not try to force anything, if you get a couple of turns and it sticks more PB run it back in then back out
LR03NJ
Mar 8, 2016 04:37 PM
LR03NJ
Feb 20, 2016 02:46 PM
04duxlr
Jul 3, 2013 11:02 AM
FlyingZebra34
May 12, 2012 05:55 AM
coors
Nov 28, 2011 06:46 AM
