How to Remove Diff Breather Tube?
I was able to remove the breather tube from the nipple on the rear diff axle and traced it to a black plastic union with green caps on the two ends of that union. How do I disconnect the breather from this union? To check if the breather is blocked do I only need to check the portion that goes from the diff to the union? Or do I need to worry about the "top" part of the breather? It goes into somewhere I can't see at all.
Thanks.
Alan
Thanks.
Alan
It's in his post Mike:
"To check if the breather is blocked"
It sounds like someone installed extra long wading breathers, that likely run up into the engine compartment.
Have a look at this waders install page maybe that will help.
http://www.discovery2.co.uk/breathers.html
