How to Remove Diff Breather Tube?
Old Mar 28, 2009 | 03:10 PM
Disco Alan's Avatar
Default How to Remove Diff Breather Tube?
I was able to remove the breather tube from the nipple on the rear diff axle and traced it to a black plastic union with green caps on the two ends of that union. How do I disconnect the breather from this union? To check if the breather is blocked do I only need to check the portion that goes from the diff to the union? Or do I need to worry about the "top" part of the breather? It goes into somewhere I can't see at all.
Thanks.
Alan
Old Mar 28, 2009 | 04:02 PM
This is a DII?
Old Mar 28, 2009 | 04:13 PM
Disco Alan's Avatar
I forgot to mention it's an 03' D2 ...
Old Mar 28, 2009 | 04:16 PM
No problem, I cant help you as I have not seen a '03 axle breather.
On a DI it is a 90 degree brass nipple that just screws into the axle housing.
Old Mar 29, 2009 | 12:05 AM
Disco Alan's Avatar
Thanks Spike. I've already disconnected the axle housing side. It's the "other" end that I'm not sure. Anyone?
Old Mar 29, 2009 | 09:20 AM
Why are you wanting to remove the tube anyway?
Old Mar 29, 2009 | 10:39 AM
rrhyne's Avatar
It's in his post Mike:
"To check if the breather is blocked"
It sounds like someone installed extra long wading breathers, that likely run up into the engine compartment.
Have a look at this waders install page maybe that will help.
http://www.discovery2.co.uk/breathers.html
Old Mar 30, 2009 | 11:46 AM
Disco Alan's Avatar
I found out the green caps were protective covers for the union. I used a flat blade screwdriver to pry one out and underneath is the red spring-loaded part I expected to find. Pressed on the red part and the tubing came right out.
MC04DII
Nov 29, 2012 08:02 PM
Ad!
Mar 24, 2012 12:50 PM
mherson
Oct 29, 2009 10:54 PM
falcontech
Feb 5, 2008 04:04 PM
brianex
Jan 9, 2008 09:08 PM
