How to Remove Underbelly Panel on '03?
Old May 9, 2009 | 11:38 PM
Disco Alan's Avatar
Default How to Remove Underbelly Panel on '03?
I was getting ready to change coolant on my '03 today and couldn't get the underbelly panel off to access the lower radiator hose. After looking up a couple posts here there seems to be 2 options - either remove the drag link and steering damper or jack the front up at the frame. I don't have the proper tools for either at this time so I have a couple questions to determine the path of least resistance:
1] Do I need to remove BOTH the drag link and the steering damper to take the underbelly panel out? It looks like just removing the steering damper MAY yield enough space.
2] RAVE shows a special tool to remove the drag link from the drag arm. Can a 2 jaw puller be used instead? If not what can I use?
3] I have a 2 1/2 ton floor jack but no jack stands. Before I go out and buy some jackstands just for a coolant change does raising the front make taking the underbelly panel out SIGNIFICANTLY easier than the drag link and steering damper removal?
Thanks.
Alan
Old May 10, 2009 | 10:35 AM
First, the cover serves no purpose other then getting in the way and addingh additional heat to the engine compartment. That being said, tear it off, throw it away, I did it 7 years ago as many others have done.
See!!
Old May 10, 2009 | 11:21 AM
Disco Alan's Avatar
Nice picture Mike!
One more question to help with my decision - I've ordered the "tall" K&N oil filters 3001 after researching the forum. If the underbelly pan isn't going to fit with the tall filter then it makes my decision REAL easy.
Old May 10, 2009 | 11:34 AM
Disco_Fever's Avatar
It'll still fit with that filter. I'm running that filter and still have the belly pan on my truck.
Old May 10, 2009 | 10:14 PM
Disco Alan's Avatar
Update: I managed to remove the underbelly pan after removing the steering damper. It took some bending and pulling and I put some small cracks in the pan in the process but it's intact for the most part.
Old May 11, 2009 | 11:16 AM
03DiscoSE's Avatar
I didn't have to remove anything to get the pan off.....just took some looking around and figuring out the best path to get it with a few twists and turns.
Old May 11, 2009 | 11:27 AM
Disco Alan's Avatar
Good for you 03Disco. I couldn't figure that out.
Just curious - is your truck lifted? Was your truck on jackstands?
Old May 11, 2009 | 02:02 PM
jycsalas's Avatar
I pulled the pan on my friends 04 by removing the steering damper. I removed MINE by bending it until I snapped it a couple pieces. Neither times were the Discos lifted nor on jack stands.
Old May 11, 2009 | 04:22 PM
Disco Alan's Avatar
It sounds right jycsalas. I consider myself fairly mechanical-minded and I was just very very surprised that anyone can take the underbelly pan off an '03/'04 in one piece without removing anything. Yes I agree that after I took the steering damper out the pan came out just fine with moderate force.
Old May 11, 2009 | 10:34 PM
03DiscoSE's Avatar
I had mine on a lift when changing the oil at work. I took it off in ONE-PIECE and had it off for a months and put it back on about a month ago in ONE-PIECE. All it takes is a little finagling and a couple of shifts in direction but it is possible.
