How to replace the XYZ switch?
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
I don't use the menu system, I just go to the particular folder, "LT" is the one with all the Disco 2 items. "General" has overhaul section.
or you can use the alternate link in my signature and just download the sections desired already in pdf.
Hopefully you can clean it out and reseal it. Some say the AC condensate drain keeps it wet, some have rerouted drain slightly with extra hose.
.-Well. I have the "m" & "s" lights flashing, and I took it to a Land Rover service shop, they told me it could be a problem with the battery and the alternator, I changed both, they told me if the battery and alternator are good it should be the XYZ switch...
