How to replace the XYZ switch?
Old Jul 19, 2012 | 03:34 PM
Xavier Campos Mercado's Avatar
7th Gear
Default How to replace the XYZ switch?
.-Hi I got a Disco II 2003, and I would like to know if you guys know how to do it or if you have any advices. Thank you...
Old Jul 19, 2012 | 04:57 PM
Bkreutz's Avatar
Download the Service Manual, it has instructions. (RAVE, in my signature) This is answering your question, not telling you that you need to replace that switch.
Old Jul 19, 2012 | 05:30 PM
The ARLO site has had write up on removal, drill out rivits, clean out muck, reseal.
Old Jul 19, 2012 | 11:05 PM
7th Gear
.-Can you explain me how to access the manual? I mean I already downloaded it, I did extract the rave.zip, but I click the "Welcome.pdf" and nothin' happen. Sorry and thank you for answer.
Old Jul 20, 2012 | 12:45 AM
Bkreutz's Avatar
I'm trying to remember exactly how I opened it, I think what I did was to download the file, extract that file to another folder, then ran "autorun" from the extracted folder. (at least that's how I think I did it.) it must have been simple because if it isn't I end up calling my son (the computer engineer) to do it.
Old Jul 20, 2012 | 05:18 AM
I don't use the menu system, I just go to the particular folder, "LT" is the one with all the Disco 2 items. "General" has overhaul section.
or you can use the alternate link in my signature and just download the sections desired already in pdf.
Hopefully you can clean it out and reseal it. Some say the AC condensate drain keeps it wet, some have rerouted drain slightly with extra hose.
Old Jul 20, 2012 | 08:57 AM
How do you know you need to replace the switch and be specific?
Old Jul 20, 2012 | 12:45 PM
7th Gear
.-Well. I have the "m" & "s" lights flashing, and I took it to a Land Rover service shop, they told me it could be a problem with the battery and the alternator, I changed both, they told me if the battery and alternator are good it should be the XYZ switch...
Old Jul 20, 2012 | 12:46 PM
7th Gear
Thank you. I'll try it...!!
Old Jul 26, 2012 | 01:47 PM
7th Gear
.-Ok, I replaced the XYZ switch, and it seems everything is fine now, but, what should I do if the "M" "S" lights show up again? What could it be?
