How to replace your ignition coils and wires with photos!
Old 04-09-2015, 10:32 AM
Racer X's Avatar
In addition to not needing to remove the A/C compressor, there's no mention of disconnecting the coolant lines from the throttle body heater.
Otherwise, that's a great write up, kudos!
Old 04-09-2015, 11:35 AM
drowssap's Avatar
I think it depend if you are removing it from the compartment or not, if not remove the ten intake bolts and just slide it the side.
Old 04-09-2015, 11:51 AM
Racer X's Avatar
With those nylon lines being as brittle as they are after 11 - 16 years, that might not be the way to go.
Old 04-23-2015, 09:53 AM
daxter1987's Avatar
I didn't remove the compressor i set it aside, it makes things much easier. is just four bolts and a connector, then i placed it inside the air filter box. I was also changing the cooling hoses that go to the throttle plate and setting the compressor aside makes the whole things easier. There is no need to suck out the freon or anything.
Old 07-24-2015, 12:33 PM
daxter1987's Avatar
I didn't remove the compressor, I just removed the four bolts and placed it aside, inside the air cleaner housing. It doesn't need to come off but for a couple of minutes and a lot more room its worth it
Old 10-19-2019, 09:12 PM
Gary Archer's Avatar
8th Gear
Anyone got that kind of info for a 96 disco 1 for coil pack removal?
Old 05-23-2020, 08:03 AM
jimiburg's Avatar
#4 cylinder isn't firing for me. Changing the coil packs and plugs soon and hoping that will fix the problem. Thank you for this info!
Old 07-19-2020, 01:18 PM
soarvet's Avatar
Well, I tackled this last night and finished up today. I was indeed able to replace both coil packs without removing the Intake Manifold. Only required a small 8mm combination wrench and contorting my hands a bit. Don’t be scared to try it first. So glad I didn’t have to tear the top end apart.
Tried to get you guys a picture to show you I actually did get them out. Those are the new coil packs waiting to go in. I broke The plastic fitting on the pvc breather on the intake manifold while I was moving my arm around trying to get in there. Easy fix.
Old 10-12-2021, 12:51 PM
Awitt1104's Avatar
did this fix the issue? Having the same problem with mine so I was just wondering what happened with this?
Old 06-11-2022, 05:44 PM
In this video Doug from Atlantic British shows a pretty good way to get the ignition coils back on (with the upper intake manifold off):
In Part 1 of the head gasket videos I think he takes it off too.
Quick Reply: How to replace your ignition coils and wires with photos!
