How to: Seafoam Induction Procedure
Old Aug 23, 2010 | 09:54 AM
ewok's Avatar
Can we please add this to the sticky "how to"?
These forums are great but it gets frustrating when there are so many great write-ups, as simple or as complex as they may be, that are not sticky'd to the "how to" thread.
Old Aug 23, 2010 | 05:46 PM
lipadj46's Avatar
Have you looked?
Old Aug 23, 2010 | 06:58 PM
Voyageur's Avatar
Question Lost my rubber cap...
jycsalas (and any body else who might know)
I lost the little rubber cap while I was doing something else on my DII. Do you know where to buy a replacement? Hardware store? Auto parts store. I am sure they can be found but I wouldn't know what to call it....
Any ideas?
Old Aug 23, 2010 | 08:46 PM
jycsalas's Avatar
Any ideas?
Go to any autoparts store and you will find a section where they sell vacuum lines and or the section where they sell the miscellaneous pre packaged nuts and bolts usually hanging off a rotating display. You'll find a package with an assortment of those rubber caps and one will fit it. Near it you'll also find the platsic "T" pieces for vacuum lines.
Old Aug 23, 2010 | 10:11 PM
lipadj46's Avatar
I'm not sure if people know this but you can do induction cleaning with water instead of seafoam and it works just as well. You have to do it a bit differently but info is all over google. I put 2 gallons of water through my engine this afternoon to get rid of a rough idle.
Old Aug 24, 2010 | 06:13 AM
Voyageur's Avatar
Talking Thanks for the "TIPS" Josh. Get it?
Josh,
Thank you very much. I'll hit Advance Auto this morning and pick up an assortment. I actually need on for my Honda Generator too...
David
Old Sep 18, 2010 | 07:46 AM
jayman's Avatar
Does anyone know what size for the vacuum tube? I am getting ready to do my first Seafoam treatment
Old Sep 18, 2010 | 01:06 PM
Spencerfitch's Avatar
yea I just did 1 gallon of water, now my oil is super high. Water in it of course.
Old Sep 18, 2010 | 01:48 PM
lipadj46's Avatar
Give us more information about your engine. Sort of the same thing happened to me first time I did a seafoam induction cleaning. The seafoam cleaned so well it made my front cover gasket leak like crazy, must have been some oil clot blocking a leak. I wonder if you have a stuck valve or your rings are toast and the steam cleaning cleaned the carbon out and make them leak.
You need to do a leak down test.
Old Sep 18, 2010 | 02:45 PM
Its a d1. But I really had 0 reason to do this as I just did my head gaskets and everything was squeaky clean.
I believe water just got past my pison rings which isn't a good thing either.
