How would this make my wipers stop working?
So I put a little fuse tap onto Fuse 26 to feed my oil pressure gauge switched power. If the fuse is in one slot (of the two available) the gauge works but the wipers don't. And if I put the fuse in the other slot, the wipers work but the gauge doesn't. I feel like it shouldn't be this complicated. Do I just have a bad dongle?
The other one in this photo (the left one) works great. It's connected to the headlight fuse to give a dimming signal to the gauge when the lights are turned on.
Ideas?
Ideas?
The following 2 users liked this post by Brandon318:
Richard Gallant (02-23-2022),
SundayFunday (02-26-2022)
@Brandon318 I was going to ask if you had both fuses in, I forgot one and when down the same path of am I crazy
Brandon318 (02-23-2022)
