How would you fix this?
Old Oct 18, 2018 | 04:16 PM
Sixpack577's Avatar
So,
Ultra-gray
or
JB Weld
I can agree with either.
They both have pro's and con's.
I have no plans to do much, if anything, to it anytime soon.
Thanks again for all the input.
Old Oct 18, 2018 | 04:32 PM
No Doubt's Avatar
Originally Posted by Sixpack577
So,
Ultra-gray
or
JB Weld
Put the ultra-gray around the new freeze plug and install. Then cover the entire surface with a layer of JB Weld.
Old Oct 18, 2018 | 05:03 PM
Extinct's Avatar
if you if you really want it fixed right the thing to do would be weld up the id of the casting plug bore and then bore it out to the OEM size and it will be as good as new. By the way to one of the other posters, those are not actually freeze plugs they're casting plugs and they are not designed to pop out if the Block freezes, that's just a lucky side effect sometimes. Having Frozen a block once I can tell you that they do not save the block always, I froze a 3.8 L Buick V6 once and it cracked the jacket in the lifter gallery.
I would assume any repair cost would be borne by the shop that screwed it up.
Old Oct 18, 2018 | 05:32 PM
Sixpack577's Avatar
So you think that surface can be tig welded?
How well does cast aluminum tig weld?
Old Oct 18, 2018 | 05:33 PM
Sixpack577's Avatar
Ha! Yeah, that's what I was thinking.
Old Oct 18, 2018 | 05:39 PM
Nosugar0carbs's Avatar
Find a good welder, make blanking caps and weld them in. Jb and permatex “might” do the trick.
Old Oct 18, 2018 | 05:45 PM
Sixpack577's Avatar
Yep, the might is what concerns me.
I don't want it failing on me...or the next guy, if I sell or trade it.
I like the welded caps idea, but am unsure how well it would stick to cast. It would also cost alot more than I want to put into it.
Old Oct 18, 2018 | 07:19 PM
Find a good aluminum welder.
Old Oct 18, 2018 | 09:46 PM
Sandman614's Avatar
Good enough for Jay Leno and his fine collection of cars
Old Oct 19, 2018 | 03:33 AM
The Deputy's Avatar
They've been called freeze plugs since the beginning of time, and do pop out...l've seen it several times in my career. And yes, sometimes they don't. But, l guess we can change the name today...but good luck at the parts store when you ask for casting plugs...you are going to get a stone cold stare from the parts guy at the counter...lol.
​​​​​​​ Brian.
