How would you tackle paint over lettering on Disco 2?
Do anyone have suggestions on on you would tackle getting off paint off the “Discovery” lettering on rear door and “Land Rover” on hood that someone painted over?
also overspray paint on driver door handle. Appears enamel.
It is supposed to be 2001 Disco 2 “Oslo Blue” but someone did a very shotty brighter blue. I intend to have it repainted, but it might be a year from now. Thank you in advance.
Hood
Hood
Rear Door
Hood
Hood
Rear Door
1999 to 2003 have the thinner hood decal:
https://www.britishpartsofutah.com/D...g100370lqq.htm
https://www.britishpartsofutah.com/D...g100370mad.htm
2004 uses the thicker version:
https://www.britishpartsofutah.com/D...O-p/rcd2lr.htm
Since you are not planning a repaint until a year later.... but still want the letter decals to look nicer... perhaps plastidip the decal (with masking tape around the letters)?
DevGru (05-22-2024)
Heat gun and dental floss may work. Apply heat first .... then use a thin sharp exacto knife to separate the paint along the outline of each letter first.... this is to ensure you do not accidentally peel the surrounding paint around the letters... then try slipping the dental floss under the letter... and gently peel off.
DevGru (05-22-2024)
