HVAC Blower motor help
Old 11-02-2018, 08:37 AM
DiscoBuckeye's Avatar
Default HVAC Blower motor help
After my recent rebuild I noticed my blower motor was making some odd noises. My suspicion (mouse nest) were correct. I totally cleaned the area out and reassembled. It worked great for a few days. Now it is dead. I pulled the electrical connector and plugged back in hoping it was a simple fix. That did not work. I am thinking maybe motor resistor but I thought when those go, the fan either works on high only or intermittently. How can I diagnose the blower motor resistor? Can you help me troubleshoot? Could it be a bad relay?
Thank you
Old 11-02-2018, 12:08 PM
Tested the motor directly and it ran. Also replaced fuse #7 under the steering wheel as well. Still does not run.
Old 11-02-2018, 01:43 PM
Best4x4's Avatar
Received 2,272 Likes on 1,676 Posts
Check the connector to the blower relay isn’t melted (common on most vehicles).
It’s mounted a little further up from the actual blower connector.
Old 11-02-2018, 03:18 PM
acg's Avatar
acg
acg is offline
I faced similar symptoms last year... checked fuses, direct powered blower motor (and it works), etc. This is how I fixed mine (see last post):
https://landroverforums.com/forum/di...or-motor-85189
Good luck!
Old 11-02-2018, 03:31 PM
I will chase that down. Thank you!
I'll check back
Old 11-02-2018, 03:43 PM
Best4x4's Avatar
No problem
Old 11-02-2018, 04:33 PM
No problem
not sure I see the relay
Old 11-02-2018, 06:11 PM
Best4x4's Avatar
Ok in that pic see the upper white connector with a Red & Black wire secured to the blower housing? Disconnect it & check the wiring on the back side for being melted or inside the connector itself. I’ve seen those get nasty. Also double check any fuses for the HVAC.
DiscoBuckeye (11-02-2018)
Old 11-02-2018, 06:16 PM
I thought #7 under the steering wheel was the one?
Old 11-02-2018, 07:13 PM
Best4x4's Avatar
I don't have the RAVE or manual near me, but it's either that connection is melted or possibly a fuse. Do you have a meter? Turn on the HVAC and see if you get any voltage. Normally when a blower resistor goes out = you loose the slow speeds and only have High.
Quick Reply: HVAC Blower motor help
