HVAC Blower motor help
Old Nov 2, 2018 | 08:37 AM
DiscoBuckeye's Avatar
Default HVAC Blower motor help
After my recent rebuild I noticed my blower motor was making some odd noises. My suspicion (mouse nest) were correct. I totally cleaned the area out and reassembled. It worked great for a few days. Now it is dead. I pulled the electrical connector and plugged back in hoping it was a simple fix. That did not work. I am thinking maybe motor resistor but I thought when those go, the fan either works on high only or intermittently. How can I diagnose the blower motor resistor? Can you help me troubleshoot? Could it be a bad relay?
Thank you
Old Nov 2, 2018 | 12:08 PM
Tested the motor directly and it ran. Also replaced fuse #7 under the steering wheel as well. Still does not run.
Old Nov 2, 2018 | 01:43 PM
Best4x4's Avatar
Check the connector to the blower relay isn’t melted (common on most vehicles).
It’s mounted a little further up from the actual blower connector.
Old Nov 2, 2018 | 03:18 PM
acg's Avatar
acg
I faced similar symptoms last year... checked fuses, direct powered blower motor (and it works), etc. This is how I fixed mine (see last post):
https://landroverforums.com/forum/di...or-motor-85189
Good luck!
Old Nov 2, 2018 | 03:31 PM
I will chase that down. Thank you!
I'll check back
Old Nov 2, 2018 | 03:43 PM
Best4x4's Avatar
No problem
Old Nov 2, 2018 | 04:33 PM
No problem
not sure I see the relay
Old Nov 2, 2018 | 06:11 PM
Best4x4's Avatar
Ok in that pic see the upper white connector with a Red & Black wire secured to the blower housing? Disconnect it & check the wiring on the back side for being melted or inside the connector itself. I’ve seen those get nasty. Also double check any fuses for the HVAC.
Old Nov 2, 2018 | 06:16 PM
I thought #7 under the steering wheel was the one?
Old Nov 2, 2018 | 07:13 PM
Best4x4's Avatar
I don't have the RAVE or manual near me, but it's either that connection is melted or possibly a fuse. Do you have a meter? Turn on the HVAC and see if you get any voltage. Normally when a blower resistor goes out = you loose the slow speeds and only have High.
