I could really use some help
Old Sep 19, 2011 | 05:55 PM
Straight Shooter's Avatar
8th Gear
Default I could really use some help
Long story short, have done the head gaskets and everything was fine then I started to see oil from around the drivers side head (between head and block). Being very picky I pulled the head to correcrt problem only to find everyhting looked fine but the combustion chamber and piston hah alot of carbon build up. It didn't have this much the first time I did it and it had 60000 on it and this time was 5000 miles. The problem I see is oil in all the intake plenum runners. I cleaned the pcv valve in the valve cover (pcv was very clean and hose looks good and all cylinders look perfect. Any suggestions are greatly appreciated.
2004 disco
68000 miles.
drowssap
May 9, 2015 01:36 PM
drowssap
Jan 3, 2012 08:59 AM
DiscoIIBrandon
Mar 11, 2011 12:01 PM
DirtyApe
Dec 25, 2008 09:07 PM
rattlegun
Apr 21, 2008 02:33 AM
