I dont know?? HELP
Old Sep 5, 2009 | 10:51 PM
IDAHODISCO's Avatar
Angry I dont know?? HELP
Ok I just had to do a head gasket change because cyclender one was sucking coolant I also did my spark plug wires and cleaned hoses!
Arround the same time this happen I was having another issue that I thought was associated with the blown head gasket I was haveing a low idle and a rough idle!
Well the low rpm and rough idle is came back but not all the time infact I cant get her to do it I played with everything under the hood and shifted gears, along with a yellow blinking and now just stays on light, so tomarrow I will hose the engine down if I can get her to do it again.
Just a recape Cold or Hot and after I shift it into Drive or Revers it gets a rough idle and a low rpm! This never hapens while RPM are up or driving??
I think it must be a sensor or something any ideas???
Old Sep 6, 2009 | 12:00 AM
possibly owner's Avatar
Sounds like a vacuum leak. Get some carb cleaner and spray the hoses and such and see if the idle improves. you don't have to soak it, just mist it. Try that and see what happens.
Old Sep 6, 2009 | 01:11 AM
NiteTrain's Avatar
whens the last like you ran some sea foam through the intake?
Old Sep 6, 2009 | 01:19 PM
IDAHODISCO's Avatar
I did the seafoam 4 month ago but I just cleaned every valve by hand, will electrical cleaner work instead of the carb cleaner that should be rubber friendly?
armyeng
Mar 8, 2011 05:58 PM
03discoman
Jan 18, 2010 10:11 AM
financialwiz101
Jul 12, 2009 03:11 PM
WolfPack
Feb 1, 2009 10:58 AM
BADBUZzZzZz
Jan 28, 2008 11:38 AM
