I have a feeling my disco is running rich.
Old Nov 14, 2008 | 04:07 PM
pit_ownr's Avatar
Default I have a feeling my disco is running rich.
Is there any way to find out whether it is or isn't? I have no check engine light.
Old Nov 14, 2008 | 08:01 PM
Default RE: I have a feeling my disco is running rich.
Other than doing a emissions test, no, not that I know of.
Old Nov 14, 2008 | 08:50 PM
Camdisco24's Avatar
A drop an MPG is usually an early sign, so check that out. You will probally throw a code eventually, thats what mine did. Your MAF might be going out the door.
Old Nov 15, 2008 | 07:37 AM
With no light on it is not running rich. Why do you think it is?
Old Nov 15, 2008 | 09:28 AM
hazletbassist89's Avatar
Check the bulbs in your dash. Make sure none are blown or removed. Like Mike said, if it were running rich it would put a light up on the dash.
Old Nov 15, 2008 | 12:51 PM
pit_ownr's Avatar
well the lights have come on before in the last month but not for that. so i know the lights work. also can anyone give me detailed location of the idle control valve.
Old Nov 15, 2008 | 05:04 PM
NiteTrain's Avatar
O2 sensors should throw a code if it's running rich, what makes you think it is? Using mass quantities of gas is normal, unfortunately.
Old Nov 15, 2008 | 05:13 PM
ORIGINAL: NiteTrain
That is the funniest thing I have heard all week.
Old Nov 15, 2008 | 08:49 PM
ORIGINAL: pit_ownr
Why are you thinking you need to find the idle control unit??
You don't really want to mess with it.
Old Nov 15, 2008 | 08:54 PM
pit_ownr's Avatar
well it has a problem idling high. about 1200 rpms.
