I have a new code for you all
P2600 Coolant Pump Control Circuit Open.
It's a generic code according to the web. Water Pump/Coolant pump is new (less than a year old).
I am at present trouble shooting a over heating issue that happened right before Christmas.
Replaced quite a few parts of the cooling system. Thermostat, Radiator, Water Pump, new hoses, hose clamps. New t junction, new bleeder screw. Truck had the head gasket done in October along with top hat liners.
I used a Air lift air vac system to add the coolant and still have a very small leak. Very slight whooshing sound in the heater core. But I have VERY hot heat and no water in the cab.
This is stating to drive me crazy.
The code threw me as well. I scoured the Rave as well and did not find any sensor that would be connected to the coolant pump to cause a "open circuit".
Any way it is totally unrelated to my over heating problem. I think
I have air in my heater core and it wont come out. I have bleed the system per the rave instructions (about 6 times) and via a Air vac Airlift system (4 times).
Which has led me to believe that my problem is in the heater core. I have heat but I do have a very slow leak in the system but it doesn't affect the coolant level. Truck sat in my garage for 4 days with no discernible coolant drop in the reservoir or puddles on the ground. It's just letting in air some where.
I have a whooshing sloshing sound in my heater core. Floor board is dry.
With this last flush and bleed it was very minor sloshing but it was still there.
Again I have replaced every thing on this cooling system but the reservoir, reservoir cap and the heater core.
I don't know where the air is getting in and I am starting to wonder if I will ever be able to find out.
adventure95004
05-09-2019 11:51 AM
clang
11-12-2015 12:17 PM
Howdy all! Newbie to the scene. Actually, I don't even have one yet:) But I have a plan! A long one.
jdog35
04-19-2008 03:16 PM
MRDM1
03-16-2007 07:03 PM
