I have a puddle of coolant on my pass. side floor..
Old Mar 23, 2007 | 05:40 PM
deepessions's Avatar
Default I have a puddle of coolant on my pass. side floor..
bought my '99 Disco II last year Sept. and I just went on a two hour road trip that required use of the defroster most of the trip....now my ride leeks like a siv and blows coolant through the pass. side vents. I need to fill it up with coolant every 5 minute car ride. any ideas as to what this could be? heater core? anyone ever replace the heater core if so?
thank you!
Old Mar 23, 2007 | 05:46 PM
variablecheese's Avatar
4wd High
Default RE: I have a puddle of coolant on my pass. side floor..
Definitely heater core. Never replaced one in that particular ride though. sorry.
Old Mar 23, 2007 | 06:15 PM
whew! I just found out it's covered under my warrenty! what a relief!
Old Mar 23, 2007 | 10:50 PM
Boy, did you luck out.
Make sure to have the dealer clean your carpet and carpet pad, allowing them both to dry.
Also, make sure there was no damage done to the wiring inside the dash.
Mike
Old Mar 23, 2007 | 11:22 PM
tell me about it Mike! I am taking the Disco to a local shop that does work on Rovers....is this a bad move? or should I take it to the stealership?
thanks
Old Mar 24, 2007 | 10:32 AM
As long as your local shop will give you the same 1 year unlimited mileage warranty, will except payment from your service company and they have done heater cores, then go for it, I would.
Mike
corbinwelter
Jul 14, 2015 09:06 PM
acamato
Jun 8, 2013 04:09 PM
Chad215
Mar 5, 2012 05:37 PM
bikeG976
Nov 14, 2009 03:53 PM
Princess
Sep 15, 2009 08:02 PM
