I know, I know, another 3 amigos post. But I really need your guys help.
I'm about ready to drive the disco into the sea.
After chasing down this code (front-right sensor output intermittent) by replacing the hub, two short-length ABS sensors, and then finally today installing the really expensive ABS sensor that goes from the wheel all the way directly to the SLABS, the amigos persist and it's the same code.
For today's wire, I cut the original front-right sensor wire that's in the yellow connector, and left about 5 inches. I soldered the new wire to that pigtail.
Anyway. I'm at a loss. I'm not sure if this is helpful, but the amigos didn't exist until one fateful evening, I was driving down the freeway in a rainstorm, hit a pothole, and the car freaked out and threw the amigos and the rough-road P(1590?) code. It's been the same issue ever since, despite all the repairs.
The ABS module is new too.
Anything? If not, anyone want my disco? lol
Kinda funny my 04 (which I don't drive as I'm keeping as a time capsule) actually just started doing the same exact thing last weekend. Like I said I haven't driven it, and it's got the longer ABS wires (done by previous owner) which run straight to the SLABS unit. Well I cranked it up to move it (working on the 97 XD) and I get the 3 amigos upon startup.... I pull out the Nanocom and I got the same exact fault. Cleared it, single ABS light comes on, drive it until it see's the input from the sensors and the ABS light goes out. Park it for a day or two, start it up and bingo without the D2 even moving. I did have a low battery so I slapped it on a trickle charger, so I'll see if just low voltage was driving it nuts.
A few years ago my truck had an SRS fault (driver airbag). I replaced the airbag but that didn't correct the condition. I then carefully checked continuity all the way back to the DCU under the center console and eventually found a short in the connector itself! I still don't understand how that was the case, but I swapped in another connector and that solved the problem.
Why not run the new wire all the way to the SLABS as it was designed to be installed? I agree splicing it in "should" have the same effect since the fronts don't pass through any other connector, but maybe there's a problem at the SLABS connector.
