I need Help on my 2000 Land Rover Discovery!!!
Old May 10, 2007 | 07:23 PM
jofher's Avatar
5th Gear
Default I need Help on my 2000 Land Rover Discovery!!!
Hello:
I need Help!!
My land rover is flashing two lights on the dash board, and both are blinking at the same time
the Manual Mode (Green light) and the Sport Mode (also a Green light). also the Car doesn't want to start all.The Engine is cranking but doesn't want to start.
15 minutes later, the car starts like nothing happen. And both lights are not blinking any more.
Also The Engine Soon light is on.
The OBII said that
oxygen sensors are bad and 4th Gear ratio is incorrect.
can somebody help me!!!
Old May 11, 2007 | 08:45 AM
Default RE: I need Help on my 2000 Land Rover Discovery!!!
Send me your tele number and a good time to call you.
Mike
mikeljacobs@comcast.net
Old May 11, 2007 | 08:34 PM
jofher's Avatar
5th Gear
Hello Mike
Well to start
Today in the morning the car didn't wanted to start at all.
so i went to Autozone and a bought a OBDII and gave me 5 codes
1.- P0734 (4th Gear ratio incorrect )
2.- P0174 (system to Lean Bank 1)
3.- P0171 (system to Lean Bank 2)
4.;-P0455 (Evap Emissions Control Leak (large)
5.- P0335 Crank-position Sensor A Circuit Malfunction
what do you think Mike?
were shoul i stat?
For the moment Mike
i'm not planing to repair it.
ill be taking vacation for 9 days.
ill be back the 21 of May.
talk to you soon...
Old May 12, 2007 | 07:03 AM
Your first 3 codes are because your MAF has failed.
0455 could be as simple as a loose gas cap or a bad vaccumn line.
Your crank sensor will probably need to be replaced especially since your engine won't start, I would check all the wires to it just to make sure none are rubbed thru.
If you don't have a good place to buy this stuff, let me know, I have a good shop for you.
Mike
Old May 16, 2007 | 09:15 PM
FTB 2000 Disco's Avatar
Jofher --
I had this same exact problem. DiscoMike helped me with it. All you will need to do is give your battery terminals and cables a good cleaning...really...this should do it. I used some baking soda and water, and a wire brush, and I haven't had any more problems in six months.
Good luck
jepajo
Sep 9, 2010 06:51 PM
ibxsurveying
Apr 6, 2010 07:13 PM
jofher
Nov 7, 2007 11:32 PM
avirotwild
Jul 6, 2007 09:36 AM
