I Need Major Help
Old Jul 30, 2009 | 02:43 PM
bwhalen1980's Avatar
Default I Need Major Help
I have an 03 land rover discoveryII... the truck began missing out on one of our recent trips. I have replaced plugs, plug wires and coil pack and the miss is still there code reader says cylinder four is missing i have spark at the no. 4 plug and no visible oil in the coolant and no visible coolant in the oil WHAT CAN I DO NEXT?!?!?!?! Any help or suggestions would be greatly appreciated...
Old Jul 30, 2009 | 03:24 PM
lipadj46's Avatar
If you have ruled out the #4 plug, the #4 wire and the coil then maybe it's the ECU gone bad? What kind of wires did you switch to? Most of us swear by magnecor 8mm.
Old Jul 30, 2009 | 04:00 PM
NiteTrain's Avatar
before you go replacing an expensive ECU test #4 cylinder for compression and and test #4 fuel injector. You should be able to borrow both testers from autozone or advance auto.
Old Jul 30, 2009 | 10:18 PM
oljohnboy's Avatar
does the engine miss all the time or when accelerating? only at idle? any extranious noise when missing like a ticking? smell unburnt fuel?
Old Jul 31, 2009 | 09:39 AM
Only 1 code, or are there more, is it a 304 or something else?
Don't throw any more money at it till we can kick this around a little.
Old Jul 31, 2009 | 12:22 PM
only missing on acceleration... 304 is not the only code it is also reading 1300 and 0300... and there is also a ticking noise but that's a whole other story in itself I am told the ticking is common in these motors is this true? Anyway sounds more like a knock than a tick and when I took it to the shop they replaced rocker shafts lifters and cam and then told me they couldn't fix it!
indiefantv
Nov 5, 2012 10:10 PM
OkieRover23
Jan 3, 2012 02:07 PM
fuze-17
Sep 9, 2011 02:24 PM
jmrmode
May 9, 2008 11:27 PM
direwolf41
Freelander
Jan 15, 2007 11:17 PM
