I need to replace a catalytic converter. Suggestions
Old Aug 23, 2015 | 01:44 PM
  #31
bcolins's Avatar
Originally Posted by Motorhead1
Ok, so I'm not a certified ASE mechanic, but this sounds like an open loop vs. a closed loop situation with the O2's?? I could be completely wrong, but when your system goes into closed loop after running for a short time, your down stream 02's are telling you that your cats are bad with the fluctuating voltages. I'm not sure if voltage readings from 02's vary between open loop and closed loop? I haven't researched this. I guess if I was ASE patched, I would already know this...
I need to maybe read back on this thread, but didn't you write this engine is burning a quart of oil every thousand miles? If that's the case, your cats are probably toast....MO
Yes, 1000 miles OR LESS per quart of oil. I never see it smoking out the tailpipe,...but I can smell the oil burning in the exhaust whenever I walk around the back of the truck with the engine running.
Old Aug 23, 2015 | 02:26 PM
  #32
bcolins's Avatar
Originally Posted by drowssap
1450 would be evap. loss system No? it prevent gas from evaporating out of your tank into the atmosphere. to big a leak and it will trip a code; have you replaced the filler cap??
Just seeing this, yes,...I tried to have my truck inspected yesterday after resetting my 1450 code. All looked good, until the very end where they found my gas cap was leaking and I had 3 "not Ready" alerts,...returned home and ordered an OE cap,...and now need to put some miles on the truck until all monitors are ready,...then keep my fingers crossed.
I also crawled under the truck yesterday while it ws running. Using my infrared laser temp gun,....I could see that the exhaust pipe temps just behind the cats was just about the same as the temp of the pipe just before the cat. Seems like it would be hotter after the cats if they were working.
Old Aug 25, 2015 | 09:31 AM
  #33
jfall's Avatar
I bought a cat assy from Atlantic British for my D1 years ago on Sale for $600.
It works great.
Assuming they have a different one for the D2 but basically the same.
Here is my D1 writeup
http://jeffreyfall.com/landrover
Will apply mostly to the D2 also.
I had a D2 with a bad head gaskets and lucky this did not affect my cats.
If your cats are bad, make sure that you are not getting antifreeze into them from bad
head gaskets or bad valley gasket sucking antifreeze into a cylinder.
Old Aug 25, 2015 | 09:33 AM
  #34
jfall's Avatar
Wow - there are some dirt cheap assys found
https://www.google.com/webhp?sourcei...0discovery%202
jwmstang
Aug 4, 2022 02:30 PM
Jared9220
Jul 13, 2014 04:56 PM
jrm123180
Mar 5, 2011 08:24 AM
SUMOSINO
Feb 9, 2006 10:04 AM
mgm777
Jul 27, 2005 05:01 AM
