I start the car and it idles too high in P and N, but not always???
Old Feb 23, 2009 | 04:26 PM
Yes that vacum leak would totally do it.
Old Feb 23, 2009 | 04:41 PM
VikingDiesel's Avatar
so that hose could just be the issue where the cruise control hose is totally ripped and not even on? So just replace the hose and see if it fixes it?
Old Feb 23, 2009 | 05:03 PM
okdiscoguy's Avatar
No, that won't fix it. It is a part of the cruse control system and has nothing to do with your problem. Fixing the hoses will fix your cruise control, though.
Old Feb 23, 2009 | 05:04 PM
okdiscoguy's Avatar
Seriously? He is already confused enough.....
Old Feb 23, 2009 | 05:42 PM
The cruise runs off vacum, depending on which vacum line is unhooked it will effect idle.
Yes he should replace the hose, it may or may not fix his issue.
I should have been more specific.
And please dont call me Shirley.
Old Feb 23, 2009 | 10:38 PM
fixed!!!! thanks guys, it was the .89cents hose from autozone that fixed it. The replaced with new hose, started it right up and idle excellent, THANKS AGAIN (knock on wood, lets hope i dont write back tomorrow with the same problem)
Old Feb 24, 2009 | 08:28 AM
jycsalas's Avatar
so was it the cruise control hose?
Old Feb 24, 2009 | 05:01 PM
yes, it is, it was the cruise control hose
Old Feb 24, 2009 | 05:38 PM
okdiscoguy's Avatar
It will come back. The cruise system is completely independant of the engine vacuum. There is a vacuum pump under the jack that has a line running to the tee by the throttle. It then goes to the bladder that controls the throttle linkage, and through the firewall to the brake switch.
Wait a couple of days.... merely a coincedence..
Spike- I never called you Shirley. I called you Tina.
THEN1203
Jul 16, 2015 07:15 PM
gman21
Nov 25, 2012 05:49 PM
xtina01
Aug 9, 2012 11:22 AM
jrm123180
Oct 13, 2011 07:56 PM
discoandrew
Oct 12, 2011 05:13 AM
