I too have a few codes I need translated
Old Jun 3, 2009 | 06:21 PM
sparky's Avatar
Default I too have a few codes I need translated
Here goes: 2001 Disco 2, V8 with 145K miles, automatic
P1300?
P1590?
P0300 - Random Cylinder Misfire
P0301 - Number 1 misfire
P0306 - Number 6 misfire
Now let me tell you what it is doing. Loss of power while driving with the A/C on. Almost like it was cutting out, then the service engine light soon came on by blinking first then constant. This place has been the best at helping me in the past so thanks so much if you have input on this problem.
Sparky
Old Jun 3, 2009 | 07:53 PM
You need a good old fashioned tune up Sparky.
Old Jun 3, 2009 | 08:04 PM
sparky's Avatar
Thanks Spike, I forgot to mention that less than 1 year ago I had new magnacor wires and bosch plugs put in. Could those be bad or is it more detailed than that?
One other question, are all of those codes associated with a tune up?
Old Jun 3, 2009 | 09:05 PM
I do not know what the idividual codes mean, but the random mis fire codes mean weak/loss of spark on mutliple cylinders.
SO you either have bad plugs, bad wires or a bad coil pack.
Start here, pull the plugs out one at a time and check for fouling.
Then check all of the plug wires and make sure that they are all sated correctly on both the plugs and the coils.
Then reset the codes and drive it and see what comes back.
Old Jun 3, 2009 | 09:19 PM
sparky's Avatar
Thanks again Spike. Will do.
Old Jun 4, 2009 | 08:47 AM
The 1590 code is a rough road/ABS fault code cause your 3 Amigos are on.
The 1300 is a emission misfire.
What octane gas are you burning, ever use any good gas addiotive or do an induction cleaning?
Old Jun 4, 2009 | 09:35 AM
sparky's Avatar
I always use supreme fuel but no additives
Old Jun 4, 2009 | 05:00 PM
With good (name brand) gas you should not need additives, if you are using no name gas then yes, every oil change add a bottle of injector cleaner.
discogreg
Feb 23, 2013 05:38 PM
bullcrew
Dec 30, 2011 08:06 PM
okdiscoguy
Apr 26, 2010 08:32 AM
bikingteacher
Jan 10, 2010 08:21 AM
