IACV Question
Old Jun 7, 2013 | 02:17 PM
MtnRunnin's Avatar
Originally Posted by NickAdams
MtnRunnin,
Have you opened up the engine wire harness above engine on firewall to see if it got wet during pressure wash? This should be easy enough to do: un-clip it and un-tape it. Look carefully for bare or corroded wires. Also, you might want to check to see if water got in the harness through firewall, and followed to ECU connection up under glove box, causing corrosion ("fretting" in technician parlance.) Good luck!
This didn't even cross my mind! I'll check it out asap.
Thanks Nick, so far your input has put the rest of my Rover back together.
Old Jun 7, 2013 | 05:07 PM
Originally Posted by MtnRunnin
Thanks Mike, that's why I was asking what role the IAC played since it ran fine with it unplugged. I was trying to expand my knowledge on that subject.
I checked the O2 sensors with the scanner and bank 2, sensor 1 was reading 0. I swapped the two front sensors to see if the 0 reading followed. It followed, but the p0150 stayed along with a new p0154 code.
I believe I got a faulty O2 sensor from the auto parts store, so I'm swapping it today. I'll let ya'll know if that fixes the issue.
Also, I've cleaned the connections a few times to ensure there is nothing blocking signal.
Thanks
THE 154 IS NOW SHOWING BECAUSE YOU SWITCH 02'S.Take the bad one back to the parts store, they come with a 1 year warranty.
D2 2003
Nov 7, 2017 07:41 AM
leadfoot
Feb 18, 2012 01:50 PM
elboy0712
Dec 19, 2010 02:48 PM
Suede
Apr 28, 2010 10:07 PM
tomfraser
Jan 3, 2009 06:50 PM
