Idiot Light...
Old Jul 15, 2009 | 12:30 PM
SFlynn2nd's Avatar
Default Idiot Light...
"trailer" idiot light flashes only when the right turn signal is used ?? The turn signal only flases once ??
Any thoughts ?
Old Jul 15, 2009 | 04:29 PM
llPANCHOll's Avatar
Mine does this as well..
But I think its whenever I signal either direction..
The trailor light goes off after the first flash.
Are you saying your blinker only flashes once?
Old Jul 15, 2009 | 04:44 PM
SFlynn2nd's Avatar
Yes ... the blinker only flashes once (at least on the inside)... My son says no flash on the outside front or rear. Bad bulb ??
Thank you
Old Jul 15, 2009 | 06:54 PM
The trailer light will only flash once unless there is a trailer hooked up then the trailer light on the dash will blink with your turn signals as long as the trailer lights are working correctly.
If the trailer lights are NOT working or there is NO trailer hooked to the truck then the trailer light on the dash will only blink ONCE.
Old Jul 15, 2009 | 07:50 PM
Time to clean/replace all sockets and check all connections at the back of the truck with a meter to find this one.
Old Jul 16, 2009 | 12:56 PM
SFlynn2nd's Avatar
Thank you
clint70
May 18, 2015 04:47 AM
99Discovery
Oct 14, 2013 02:15 PM
Higgy
Freelander
Jan 27, 2010 05:40 AM
AK Rover
Aug 7, 2008 06:48 PM
apcollin
Nov 29, 2007 12:18 PM
