Idiot of the year award
Old Jul 25, 2019 | 06:33 PM
escott16's Avatar
Default Idiot of the year award
Well guys I’m taking the idiot of the year award. I was moving some cars around including my disco and I have another car that was running and is very loud I somehow forgot the disco was running left for work. I came home to it not running and out of gas. It had a fan clutch issue so I was afraid it overheated but I’m checking the oil and coolant and they look fine but now the car won’t start at all, just keeps turning over . I used the scanner to engage the fuel pump since it’s hard to hear and the lights dim a tad but still won’t start , so what I did was sprayed starting fluid in it it started , ran reallly rough (after putting 3 gallons of gas in ) I turned it off re did it after checking fluids again and the engine was able to idle and move under its own weight but once I turned key off it won’t start again , would this be a fuel pump or did I overheat it and how gaskets , and I already checked the relay and fuse it’s good and I checked the inertia switch
Old Jul 25, 2019 | 07:37 PM
Stein's Avatar
I'ld put more gas in it and try to get it started. 3 gallons isnt enough if the tank was completely empty.
I'm not sure how well these engines are oiled at idle RPMs, but I would guess you put lot of wear on the internals.
Old Jul 25, 2019 | 08:20 PM
jkid's Avatar
Wow that’s a good one. I’d want to check the fuel pressure and make sure the pump is good. I’d imagine it’s pumped a lot of fuel in its life already and pumps don’t like to be run dry. The fan clutch issue sounds like a problem but it sounds like it at least was running until it ran out of fuel
Old Jul 25, 2019 | 08:36 PM
Ben Matheson's Avatar
I agree add more fuel
Old Jul 25, 2019 | 09:34 PM
escott16's Avatar
Got it up to a qtr tank if I use starting fluid it will start then run and stay running , but the second I turn it off it won’t start again . I used the Hawkeye to engage the pump I can hear the whining in the rear
heres a video showing it idling strong then me turning it off
https://share.icloud.com/photos/0Cc-...PMa80OBvU5W18w
Old Jul 25, 2019 | 09:48 PM
Slap it in gear and drive it like you stole it. I'm guessing you sucked some crud from the bottom of the tank
Old Jul 26, 2019 | 12:02 AM
Frank4's Avatar
We call that the Italian tune up.
Old Jul 26, 2019 | 06:04 AM
Jason Feuerstein's Avatar
That sounds like the valve in the fuel pump that prevents fuel from draining back into the tank doesn't work anymore. Can you get a pressure gauge on the Schrader valve at the back of the fuel rail?
Old Jul 26, 2019 | 06:24 AM
escott16's Avatar
Is it easily accessible or do I have to remove the manifold or something
Old Jul 26, 2019 | 06:37 AM
That depends. Do you, by any chance, have hands the size of a toddler?
