If you DID fix the three amigos, what was the faulty component ?
Old 12-09-2012, 11:02 AM
Externet's Avatar
Post If you DID fix the three amigos, what was the faulty component ?
Trying to collect a list of the solid proven causes for the problem. If the fix was achieved by replacing multiple items simultaneously, it may not give a solid clue to what was wrong.
Please post to tell us how did you successfully cured this cancer by precise replacement of which single part. It will be a useful thread for many.
Thanks.
Old 12-09-2012, 11:57 AM
jafir's Avatar
03 - I replaced the SVS, SV o-rings, and did the wiring bypass.
99 - I used the old SVS from my 03, because it tested good, and did just the wiring bypass.
Old 12-09-2012, 12:07 PM
You need to back up. First go get a scanner that read all the 16 codes for the ABS system, then fix the part and clear the code and your done with it, simple as that.
Have you even read the fault codes yet?
Old 12-09-2012, 12:11 PM
borchera's Avatar
We replaced the SVS, o-rings and the ABS modulator. Looked at the bypass and decided against creating a new electrical circuit to worry about.
There is a complete kit at AB for the shuttle valve switch error.
Land Rover ABS Modulator Valve Kit (Same Fit As Genuine Part # SWO500040) | Land Rover Brake Parts
2003 Discovery 131K with all high miles services complete.
Old 12-09-2012, 12:14 PM
That kit is rarely if ever needed as Josh's repair listed in the sticky at the top of this section will fix the same codes for around $140, valves and o-rings.
Old 12-09-2012, 12:46 PM
jafir's Avatar
That valve kit you linked to does fix the shuttle valve switch problem, and a lot of people are dead set against modifying any wiring, but my only problem with buying that kit is that there is no reason to believe that the exact same issue won't occur a couple of years down the road.
Old 12-09-2012, 01:14 PM
borchera's Avatar
I weighed the decision carefully and did the homework. Had I not been able to find the same kit on eBay for a fraction of the cost, I would have rewired the Modulator or would have done the Hummer fix with a resoldering of the pins. I would agree the bypass does work and I opted not to have an additional wiring. Another debate I had was if there was faulting soldering on the pins what else could be faulty within the Modulator?
My research also showed WABCO became aware of the manufacturing defect/ faulting soldering and produced the kit with an updated modulator (a version 2.0.) We are over a year and half with the kit and all is well.
In response to Disco Mike, the kit identified does work for those with the SVS error 114 and is being presented as a repair for the ABS as the original poster requested. I would add however a suggestion to check eBay first.
2003 Discovery 131K with all high miles service complete.
Old 12-09-2012, 02:44 PM
i had 3 amigos problems 3 times on my d2. two time it was hubs and the final time it was brake dust.
Old 12-10-2012, 09:49 AM
Eldonkey's Avatar
Fairly new to the board here.. Do the 3 Amigos NEED to be fixed ? Is it going to act up at some point on all DIi's? Just trying to get an idea of possbly adding this to the list of drve shaft replacement, head gaskets, and setting up an ultra gauge.. This obviously is in addition to the 60k/ new owner maintenance sticky..
Old 12-10-2012, 10:04 AM
MoShadeTree's Avatar
I was getting the shutter electrical error. The 3 amigo's would randomly appear but would always disappear if I cut the truck off and let it sit for a few minutes. I did the re-wiring of the valve (It tested good and not wet). Have been trouble free for 60 days and the T/C and Downhill Decent works great!!
Quick Reply: If you DID fix the three amigos, what was the faulty component ?
