Ignition Key assembly
Old Jul 22, 2017 | 01:56 PM
LR03NJ's Avatar
Im not sure how long it will hold but I just sprayed it with contact cleaner (green can from WD40) by inserting the straw inside until it overflowed and dripped. Its been starting right up but I felt like the key slot is very loose now. I'll check how long it will stay good but in case it get bad, I have a replacement. The thought of chiseling seems to be a lot of work.lol bandaid for the mean time.
Old Jul 22, 2017 | 02:10 PM
OffroadFrance's Avatar
Originally Posted by abran
^That will work.
The jbweld trick will not. The shear bolts are torqued down until the hex head breaks off.
X1 ............ Also electric welding might screw up the ECU and BCU unless you disconnect them first.
Old Jul 22, 2017 | 02:16 PM
Good luck LR03NJ, changing the ignition switch assy is to liken it to a bad dose of haemorrhoids, it's a real PITA.
Try hang onto NOT doing it as long as possible.
will rocket
Off Topic
Sep 12, 2013 06:23 AM
wheelgarage
Jun 24, 2011 05:29 PM
LRD2&ME
May 17, 2011 05:03 AM
Chrisinhouston
Nov 9, 2009 01:37 PM
harchy
Mar 11, 2009 11:03 PM
