Ignition keys
Old Jan 2, 2016 | 07:20 PM
dreamer86586's Avatar
3rd Gear
Default Ignition keys
Hello, I just brought a discovery td5 of 2003 snd it has a ignition lock changed. It has a common key (no key fob remote) to start it with and the original key with original key fob hanged with it, and fits the doorlock. The hanged key fob works well with the door locks but. My problem that for everystart I should press the key fob so the car could recognize me . This is boring. My question is " if i change the ignition lock and the doors handle lock that are paired with the ones one the car and keep the cars key fob will it eork good? Thanks
Old Jan 2, 2016 | 08:40 PM
dr. mordo's Avatar
Yes. If you get a used set of ignition and door locks with matching keyfob, you can swap the electronics from your fob.
Old Jan 3, 2016 | 01:21 AM
3rd Gear
Default re ignition
Goodmornimg, thanks for your swift reply,I will try it as soon as I can. I have another set brand new original ignition and it was as it should be with one key . I will exchange the lock and the door lock thank you
gbclowes
Dec 21, 2015 01:26 PM
Disco_Fever
Nov 1, 2013 06:14 PM
will rocket
Off Topic
Sep 12, 2013 06:23 AM
1998DiscoverySE
Jun 27, 2012 01:56 PM
II2Go
Jan 10, 2006 05:32 PM
