ignition switch question
Old Sep 26, 2008 | 03:08 PM
Simplyme1966's Avatar
Default ignition switch question
Hi all, this is my first post, hope it is not a silly one. I have been reading post on this site since Feb of this year when I bought my 1997 Discovery. I have found this site very educational and I hope someone can help. My question is about the small square box attached to the side of the ignition switch that clicks when the key is turned on or off. What is the box and how important is it? I recently had to change out my ignition switch and now sometimes my key will get stuck in the ignition and the only way I can get it out is to lift the little lever on top of this small box with a screw-driver and then I can turn the key all the way to off and remove it. Thanks in advance guys.
Old Sep 26, 2008 | 03:29 PM
Default RE: ignition switch question
Is your truck a manual? I think they stopped with the manuals in 1996.
My 1997 has no such "box" on the steering colum si I have no idea what you are talking bout, sorry.
Can you post a pic of this box?
Old Sep 26, 2008 | 03:58 PM
My truck is an auto. Here is a pic. Thanks
[IMG]local://upfiles/11586/149AECDEEC5A45C69EF002CAEA1F7D77.jpg[/IMG]
[IMG]local://upfiles/11586/B09B786B3AA64DD093BCE5FA3B9894C3.jpg[/IMG]
Old Sep 26, 2008 | 04:04 PM
I think that is theignition lock, its what keeps you from removing the key with the engine running.
Somebody who know about ignitions will chime in.
Old Sep 27, 2008 | 09:16 AM
wizard's Avatar
I think Spike555 is correct, it may be the ignition lock mechanism that locks your steering column when you take out the key.
When you rotate the key does a spring loaded steel pin come out that would go into the slot in the steering column? If this is the case then be careful that your steeringdoes not lock up when you are driving if it has been assembled incorrectly!
When I had trouble withmy 96 disco ignition switch,it ended up being a worn out lock mechanism that stopped the ignition being turned on, and it was a fiddly process reassembling all the parts correctly so that everything worked properly
Cheers
wizard from Australia
Old Nov 13, 2012 | 08:12 PM
billclemons's Avatar
my 1997 discovery key will not come out when placed in park or any position. I took the ignitioncover off and key came out put cover back on and then key would not come out. I think it is in the ignition. key does not turn off enough to lock the sterring wheel.
machinetech
Aug 19, 2014 04:18 PM
bfre49849
Oct 10, 2013 09:02 PM
will rocket
Off Topic
Sep 12, 2013 06:23 AM
1998DiscoverySE
Jun 27, 2012 01:56 PM
jaxrvr
Apr 24, 2005 12:01 AM
