I'm an idiot!!!
Old Oct 24, 2010 | 05:31 PM
cwood's Avatar
Default I'm an idiot!!!
I spent the last couple of days installing a CDL from a DI on my 2000 DII,after getting everything back together I went out for a test drive with the wife. I was going to show her that all of the time that I spent working on the DII this weekend was worth it so I found a pretty steep incline and decided to climb it. Locked CDL,put her in low range,turned the ignition off then back on, went up the incline and decided to try it again,while circling back around I had a loud POP from underneath the vehicle,at the same time the ABS ,TC AND CDL light came on which were not on before the loud pop...then I realized that I read somewhere that you are not suppose to have the CDL engaged on asphalt .. as much as I am scared to ask..... what did I break now? Thanks,CW.
Old Oct 24, 2010 | 06:02 PM
Ouch man!!
Does it drive fine still?
Old Oct 24, 2010 | 06:29 PM
NiteTrain's Avatar
why did you turn it off and back on? you can engage while engine is running. how far did you drive on asphalt?
Old Oct 24, 2010 | 06:43 PM
cwood's Avatar
Spike,it still drives fine and makes no strange sounds.
Nite Train, I turned it off then back on to turn off traction control, I believe that is how it works. I only drove it up the incline and a sharp right turn circle, less than 100 feet total. When I was doing the circle it felt like it was hard to turn or something was in a bind.
Old Oct 24, 2010 | 06:51 PM
NiteTrain's Avatar
you are correct thats how to turn off TC..I just usually leave my TC on when I engage CDL.
even weak transfer cases can be driven some on hard surface roads without much damage..ours are tough so I don't see anyway that 100' could damage it unless you were really getting on the gas almost trying to break something. Feeling like its in a bind in 4lo with CDL engaged is normal..I think you're ok...might be a good time to check/change transfer case oil it it's due for a service.
Old Oct 24, 2010 | 07:02 PM
cwood's Avatar
I was hardly moving at all, the loud pop that it made sure sounded like something broke,any ideas was that could have been.
Old Oct 24, 2010 | 07:15 PM
I bet you popped a front spring loose or back into it's normal position, this can make a hell of a pop.
Old Oct 24, 2010 | 10:22 PM
handsome rob's Avatar
The only time I have had a pop stop me was when I blew a front CV joint. I was not able to move anymore so I knew I was in trouble. If it drives fine then you should be okay.
Old Oct 24, 2010 | 10:52 PM
tweakrover's Avatar
we are assuming you disengaged the cdl after the pop.
Old Oct 24, 2010 | 10:59 PM
Camdisco24's Avatar
Do you hear any nosies from the T-case still??
