I'm an idiot!!!
Old Oct 25, 2010 | 02:16 AM
cwood's Avatar
I sure hope that all that it was is a spring making some noise but my luck usually does not go that way .
After it made the popping sound I did disengage the CDL,I pulled foward probably 75' (it seemed to may have been making a slight clicking sound from the front maybe ) and the TC,CDL and ABS lights were still on. I engaged and disengaged it another time,turned it off them back on again,all lights went off,drove home 3 miles with no noises from transfer case or front end.
So if it were a CV joint would it not move at all,any way to test to see.
Old Oct 25, 2010 | 06:26 PM
cwood's Avatar
Just got back in from looking over the LR. I jacked up the front end,put the transfer case in netural,turned each wheel by hand,the driveshaft turns smoothly with no unusual sounds as I spin each wheel . I repeated this process on the rear end with same results.
Afterwards I jacked up one of the front wheels at a time,chocked the rear wheels,put TC in high,gear shifter in drive and let off of the brakes and the wheel that was off of the ground spun freely. I also did this on all four wheels with the same results.
Does everything sound normal to you guys, also with both front wheels off of the ground and I spin one,does the other wheels suppose to spin in the opposite direction.
Old Oct 25, 2010 | 08:03 PM
Everything sounds fine to me.
Drive and dont worry about it.
Chock it upto lesson learned.
Old Oct 25, 2010 | 11:37 PM
handsome rob's Avatar
Yeah with teh CDL disengaged it would not move is you lost a front CV. It would be the path of least resistance and would just spin. It sounds like there is nothing wrong so that is good.
Old Oct 26, 2010 | 06:34 AM
cwood's Avatar
I defiantly won't do it again. Thanks for everyone's help.
AK Rover
Aug 7, 2008 06:48 PM
Jeff In Katy
Feb 26, 2008 09:43 PM
starcraft
Jan 4, 2008 07:30 PM
apcollin
Nov 29, 2007 12:18 PM
faugsu
Dec 13, 2006 10:25 PM
