I'm stumped
Old Mar 7, 2023 | 03:37 AM
Leopoldt's Avatar
3rd Gear
Default I'm stumped
Disco 2 not getting fuel.
I recently had a strange symptom while in Mozambique and eventually had to tow the vehicle back to South Africa.
It's a TD 5 and started with the engine cutting out(I was driving on a very bad dirt road)the ref counter would drop to zero but almost immediately jump back to where it the refs was.Meaning the engine was cutting out and starting up again.
Eventually the engine died but when starting up it would start immediately and idle as normal.
It would continue driving a few minutes but would not ref over 2000rpm before shutting of again.
Start as normal and idle as normal...this behaviour continued for about 70km before it stopped and would not start again.
Very little fuel supply to diesel filter and none to fuel pressure regulator.
Fitted new high pressure fuel pump the simptoms are exactly the same
Old Mar 7, 2023 | 06:04 AM
redwhitekat's Avatar
is the pump runing ? did you check voltage to pump ? maybe you got a bad fuel line ? filter ? check supply lines to filter
Old Mar 7, 2023 | 06:24 AM
Leopoldt's Avatar
3rd Gear
Filter is fine,voltage to fuel pump is fine still have to check fuel supply lines
scsand
Dec 9, 2018 09:56 PM
ajnolin
Jul 7, 2017 09:52 AM
filthydisco01
Oct 26, 2016 09:11 PM
bobm
Mar 5, 2012 07:13 PM
Dodger
Apr 16, 2011 09:54 PM
