Immaculate Rovers
Old Dec 23, 2010 | 11:37 AM
Disco2Fever's Avatar
Default Immaculate Rovers
Well boys, I'm nearly there. My very own Spruce Gooses.
In January, I have to put about $3,000 more into the 2000 Disco, but after that, BOTH my Rovers will either have all NEW parts, or their existing parts will be functioning perfectly.
The *ONLY* things remaining are two VERY slow leaks in each T-Case. The rate is so slow that my mechanic said I was perhaps 1/8" down on gear oil, and it's likely they've been leaky (moist on the outside) for several months. I'll not be having these tore down quite yet.
After this, I'll be putting money into the sound system and interior, making changes to the dash for ergonomics and to accommodate some technology which I would like to integrate. Finally, in the fall if 2011, I'll be making investments to make the cabin of the vehicle more safe from ... uh.... bullets. =)
-Disco 2 Fever
Old Dec 23, 2010 | 11:46 AM
tuck's Avatar
Hmmm.... an up armored Disco. That'd be cool.
Old Dec 23, 2010 | 12:14 PM
Disconoobie's Avatar
Before doing a reseal on those t-cases...try adding some White Shepherd...added it to mine a couple of months ago for a slow seep and it stopped it completely...
Nice job on the discos btw!
Old Dec 23, 2010 | 12:15 PM
Wow, great tip- I'll definitely do that! The mechanic said it would be 8 hours of labor to tear them out and down for a re-seal.
Thanks, friend. My job is very up and down. There have been times when both Rovers sat in the driveway idle for want of fuel, and times like these when I can start having speaker covers that are dented replaced
Not sure how long it'll last, but at least the Rovers will be tight as drums if I end up back where I started.
-Disco
Old Dec 23, 2010 | 01:33 PM
yloDiscoII's Avatar
....Finally, in the fall if 2011, I'll be making investments to make the cabin of the vehicle more safe from ... uh.... bullets. =)
Nice to hear a success story! Glad to hear you are finally getting those dented speaker covers taken care of, SHEESH!
Now, care to elaborate on that last little statement you plugged in there? I am intrigued....Here's what I picture (except a Disco)
Old Dec 23, 2010 | 01:41 PM
Thank you very much, friend.
Having a bullet-proof vehicle has always been a silly fantasy of mine, but I think I'm going to do it anyway. If nothing else, it'll make for a good story.
I don't expect to be able to stop 7.62 rounds, but for about 800 additional pounds, I should be able to stop 9mm and .40 cal rounds pretty well in the door panels. I'm not so sure about the glass, or how they'll pull that off. I know it's easy to coat regular glass with a material that requires a lot of bashing to break (which even then prevents shattering), but I doubt it would help against any sort of projectile.
Thicker reinforced glass would require re-routing of the window operation, which may be fine, since the Kevlar panels would probably require some movement as well.
I'll deal with it when the time comes. I assume I'll have to ship the vehicle off to some third party specialty shop.
If I have enough money to do this in the fall, I don't think I'll be too worried about much else! =)
-Disco
Old Dec 23, 2010 | 01:49 PM
You know, the only thing about having bullet-proof glass is that I won't easily be able to shoot OUT of the vehicle, either....
I guess that's why we have two sun-roofs...
Old Dec 23, 2010 | 02:15 PM
yloDiscoII's Avatar
Very interesting, can't for the pictures!
Old Dec 23, 2010 | 05:29 PM
NiteTrain's Avatar
if you're into bulletproof vehicles check out the BMW E67. I think you can pick those up reasonable..read a story on the bmw forum how some guy bought one and didn't know it was the security edition..he kept wondering why he was getting bad fuel mileage lol. BTW just curious do you need one for work or just into bulletproof vehicles?
Old Dec 23, 2010 | 09:44 PM
AZRover's Avatar
I want to mount a 50 cal Gatling gun on the roof that can swivel 360 degrees all from the comfort of the drivers seat......
1999rover
Nov 3, 2013 01:51 AM
cardinal77
Jan 28, 2012 12:30 AM
bcolins
Nov 16, 2008 04:35 PM
bcolins
Oct 28, 2008 01:23 AM
sathish17110
Jul 31, 2008 09:03 PM
