Improve turning radius
RE: Improve turning radius
hahahaha well as much as seattle is a ultra PC area, those who will hug a tree or freak out over some crap are the ones who jump into their H3 hummers and peel out. hahhaha
i am a middle of the road guy politically. but when it comes to the whole global warming thing, it will not keep me from my toys. besides the truck is a work rig. i routinely carry several thousand lbs of material in the bed. so at least i can say that my truck is used as a truck and not a $3.80 per gallon diesel coffee getter.
i figure between the 14mpg the diesel gets. the 13 the LR gets. the 29 the ducati gets and the 16 the ferrari gets i am doing my part to **** off a good number of seattle eco whackos. mwhahahhahahahahahahahaha
even if global warming is real, the media scam is was over blown, and theres no effective soulution, besides us all living in straw huts. im a libritarian, but usally end up supporting republicans for that reason.
They can prey the disco wheel, andBerreta 20 gauge out of my cold dead hands!!!!! [sm=badbadbad.gif]
i just bought a kimber 1911 and a S&W 642 for carry a few weeks back. my buddies thought it was because of the dems, but honestly i know its political suicide to go after americans gun rights. so honestly that was not on my mind when i bought them. it was more, "i want these now!" hahahah
"If" you have 16" wheels, but have thelonger lockstops fitted then you can change them and reduce your turning circle by up to 54 inches, as Land Rover in thier wisdom fitted the longer lockstops (designed for 18" wheels) to a lot of models that comefrom thefactory with 16" wheels,
First you need to measure the lockstops you have now, if they are 23mm in length, your stuffed, but if they are 29mm, you can change them for the 23mm stops and your turning circle will improve loads.
Here is the location of thelockstops...
Part numbers for lockstops :- "If" you need shorter ones.........
23mm FTC 5151
You can if needed put washers behind it to make it the size YOU want, so if you need 25 mm for example, to still give more clearance as all vehicles will be different, you can add 2 x 1mm thick washers.
Part number for the 1mm washers WDL112081L
23mm FTC 5151
JUKE179r (10-26-2020)
ORIGINAL: jycsalas
sloppyjoe
I have decided that you are 100% right about it not being a Geo Metro.... so thats why I have decided to trade my Discovery in for this
BETTER GAS MILEAGE AND RADIUS !!!!
sloppyjoe
bwahahahahahhahaha no we're talking.
im gonna get a dodge omni 4x4 conversion so as not to copy you.
