INFO! Needed AND Given!
Old Mar 2, 2006 | 03:47 PM
JKK's Avatar
JKK
Default INFO! Needed AND Given!
Hello All:
Well I've owned my 99 Disco I for about 7 months now (100K miles on it) & except for an alternator replacement, no real problems. She does have a leak from the cooler lines/main seal/front axle...I knew this when I bought it & took a chance so I just watch fluid levels...leaks are pretty minor. Anyone see a problem leaving those alone for the time being as I am sure that will be a hellish project one day?
FYI...I bought the entire factory service manual on CD off EBAY for $10. I took (2) 3" binders to hold it after I printed it. I think this CD supplier continually lists it on EBAY so highly recommended!
Got a few preventive maintenance items I got to get to work on so I thought I'd post these questions & hope some "Disco-Techs" could help.
As far as I know the auto tranny fluid never has been changed. The Rover shop here in town says don't change the filter but change the fluid & recommended using a place that could has the flush machine rather than strictly a drain & refill...do you all agree?
The right rear passenger door is now not wanting to open...from other posts I see it is a replacement piece only, no repair, & a common occurance...do you all also agree?
Lastly...no one seems to sell an install kit for this vehicle for aftermarket CD player (checked Crutchfield, etc. & no one has one). Any ideas where to locate one?
That's it for now! Thanks for any input you have!
JKK
Old Mar 2, 2006 | 11:02 PM
mikemeyer0's Avatar
Default RE: INFO! Needed AND Given!
I got the rave cd free, shipping was free too.
Old Mar 3, 2006 | 05:59 PM
MadBilly's Avatar
go to the shop that flushes the transmisiion fluid, it is better than just draining it. When you flush (with preesure) a transmsiion it gets out any sediment that is in the case, draining it doesn't always get it all out. As far as the trans filter, i dont know why you wouldnt change it. You can ignore the leaks as long as you keep the fluid levels in check, i have and am at about 300k on my rover. For the CD player, i would recomend just buying a factory it is less hassel than having to redo all the wiring for the speakers and everything that is involved with a new cd player.
Esfour
Nov 4, 2014 05:54 AM
s10lowrider1994
Sep 8, 2011 09:35 PM
nwaneal
Nov 25, 2008 05:21 PM
dinandan
Jul 25, 2006 12:16 PM
dinandan
Jul 5, 2006 11:36 AM
