Injector gap
Old May 24, 2007 | 05:34 AM
Seamie's Avatar
3rd Gear
Default Injector gap
Hi all.
Does any one know what the gap for the injectors and the rocker arm is for a 1998 TD5.
Thanks,
Seamie
Old May 24, 2007 | 10:51 AM
okdiscoguy's Avatar
Default RE: Injector gap
All I have is for a 300 tdi:
Valves
Tappet clearance:
- Inlet and exhaust 0,20 mm .................................................. .
Seat angle:
- Inlet 3
0° .................................................. .....................
- Exhaust 4
5° .................................................. ...............
Head diameter:
- Inlet 38,75 - 39,05 mm .................................................. .....................
- Exhaust 36,35 - 36,65 mm .................................................. ...............
Stem diameter:
- Inlet 7,960 - 7,975 mm .................................................. .....................
- Exhaust 7,940 - 7,960 mm .................................................. ...............
Valve lift:
- Inlet 9,67 mm .................................................. .....................
- Exhaust 9,97 mm .................................................. ...............
Cam lift:
- Inlet 6,81 mm .................................................. .....................
- Exhaust 7,06 mm .................................................. ...............
Valve head stand down
- Inlet 0,81 - 1,09 mm .................................................. .....................
- Exhaust 0,86 - 1,14 mm .................................................. ...............
Old May 24, 2007 | 12:32 PM
98roverguy's Avatar
I've never heard of an "injector gap" before? Can someone school me? Is it the clearance from the intake valve to the injector? Why would you ever need that unless your installing performance products?
sdsilvere38
Nov 11, 2008 04:03 PM
sdsilvere38
Sep 1, 2008 02:09 PM
2000 Disco 2 SD7
Jul 18, 2008 11:56 AM
Sooners
Oct 29, 2007 10:20 AM
sanchez
Aug 3, 2006 10:24 PM
