Injector rebuild kits
i picked up this rebuild kit for my injectors
Fuel Injector Repair Rebuild Kit B38 O Ring Pintle Cap Lower Ring Retainer | eBay
there are obvious differences from the stock setup and these, i wonder if they will be just fine or will i have to do another kit?
![](https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-xfa1/v/t1.0-9/12882_10153035704496999_961376900399933460_n.jpg?oh=46a6cad0f5392bf5f19f948da0ba6fb7&oe=5589A1D1&__gda__=1434631268_306a94745644bc50ffd7bdbae442d19f)
![](https://scontent-dfw.xx.fbcdn.net/hphotos-xpa1/v/t1.0-9/12891_10153035704686999_551381734405514516_n.jpg?oh=1923c7699c6331adf03d11cc7cbe9f8e&oe=55BB0655)
Hi ls1morethanyou, I may be wrong about the V8 injectors but the LR TD5 diesel injectors are all coded to each cylinder via the ECU and the internal electronic actuation is different for each. This only applies if you are changing them or refurbing the internals which requires Test Book or similar to set them up again.
A little more explained here:
Td5 Injector coding - Defender Forum - LR4x4 - The Land Rover Forum
As I said, it may not apply to the V8 injectors but worth warning you in case.
