Injector rebuild kits
Old Mar 15, 2015 | 10:02 PM
ls1morethanyou's Avatar
Default Injector rebuild kits
i picked up this rebuild kit for my injectors
Fuel Injector Repair Rebuild Kit B38 O Ring Pintle Cap Lower Ring Retainer | eBay
there are obvious differences from the stock setup and these, i wonder if they will be just fine or will i have to do another kit?
Old Mar 16, 2015 | 07:46 AM
ralphobell's Avatar
This is the kit you need.
http://www.mrinjectorparts.com/store..._Item_TF6.html
Old Mar 16, 2015 | 07:57 AM
OffroadFrance's Avatar
Hi ls1morethanyou, I may be wrong about the V8 injectors but the LR TD5 diesel injectors are all coded to each cylinder via the ECU and the internal electronic actuation is different for each. This only applies if you are changing them or refurbing the internals which requires Test Book or similar to set them up again.
A little more explained here:
Td5 Injector coding - Defender Forum - LR4x4 - The Land Rover Forum
As I said, it may not apply to the V8 injectors but worth warning you in case.
Old Mar 16, 2015 | 08:58 AM
The pintle cap Is a different style than the stock one on the right. But even that rebuild kit you showed has that style pintle cap cover
Old Mar 16, 2015 | 09:12 AM
dusty1's Avatar
I told you what I think......can't see how the profile will change anything, other than looks. the seal is the same and spray and depth look the same.........I think it just a different style.........but I really don't know fosho
Old Mar 16, 2015 | 11:06 AM
well they are going in either way haha
Old Mar 16, 2015 | 11:13 AM
dusty1's Avatar
if you look at it, it appears to be an improved design. the non corrosive plastic is taking the place of the old style metal o-ring lid.
$9.72 says it will work perfectly...
wait......just found a quarter. so, $9.97.
Old Mar 16, 2015 | 03:08 PM
ralphobell's Avatar
lube it, lube it real good, and they will fit!
Old Mar 16, 2015 | 06:26 PM
cybercop's Avatar
What is instigating you to replace the injectors?
Old Mar 17, 2015 | 02:58 PM
i didnt replace them, i rebuilt them since i had pulled them off and the seats were in bad shape.
