Inlet manifold
Old Feb 12, 2022 | 06:59 AM
Auzzy's Avatar
Default Inlet manifold
Hi all my 2004 disco 2 petrol overheated the other day. Did a pressure test and found it leaking from the throttle body, fixed that and pressurised cooling system and as it lost pressure i could hear water being pushed into the inlet manifold. Looking for some ideas to what's happened and needs repairs. I'm guessing hg has failed.
Old Feb 12, 2022 | 10:20 PM
Richard Gallant's Avatar
Not that simple if you can hear it is usually external, spend 40.00 get some UV dye and a flashlight. Dump the dye in run the engine at idle, WATCH YOUR TEMP once it gets good a warm shut it down. Use the flashlight to look for leaks, you can check hours later that stuff really glows under UV in the dark.
It could be a valley pan gasket, intake hose on top of the manifold, or even an external head gasket leak.
Dave Maynard
May 12, 2021 05:22 PM
The_OGCJR
Dec 18, 2015 07:17 PM
aftermath431
Feb 24, 2014 03:56 PM
autopia
Jul 30, 2010 11:12 AM
2002FreebieSE
Dec 8, 2006 09:14 PM
