Inline 180 Stat Mod - Overheating
Old Dec 12, 2015 | 09:55 AM
ZGPhoto's Avatar
When is the last time you replaced the clutch on your viscous fan?
Old Dec 12, 2015 | 10:02 AM
coors's Avatar
Originally Posted by morbengan
The only thing I can figure is that there has to be enough coolant flow even when closed for the hot coolant to reach and open the thermostat.
Correct. This was my issue. I'm sticking with one hole for now. I'll see what happens over the course of a couple days. If temps continue to fluctuate and I'm sure all air has been expelled then, I'll drill a second hole.
Old Dec 12, 2015 | 10:04 AM
coors's Avatar
I believe the Fan clutch is good. Can only assume its the factory original. 124,xxx miles from '04.
Old Dec 12, 2015 | 10:44 AM
ZGPhoto's Avatar
Have you tested it?
Old Dec 12, 2015 | 11:05 AM
coors's Avatar
Driving home from my old man's shop - she ran good 185.0 on the highway. Consistently.
Idle temps peak at 188.6 then drop to 183.2.
Whatever air was "trapped" is gone now. I'm stoked.
coors's Avatar
Have you tested it?
Nah. It's good.
Old Dec 12, 2015 | 05:52 PM
cappedup's Avatar
That's great.
I'm interested in this mod. Did you follow a certain bunch of info?
I'm at 104k right now. Original HGs. Temps great. But I want to see if I can push the HGs as far as possible. While I rarely see 201deg at idle, as a spike, I do see an inline stat as a really good move.
Old Dec 12, 2015 | 11:32 PM
coors's Avatar
Originally Posted by cappedup
That's great.
I read a sh$t ton of threads before moving forward with mod - the good the bad and the ugly. In the end, I curbed all my fears about possibly encountering closed loop conditions and poor fuel economy. Hell, Nintendo was more advanced than our ECU's.
I highly recommend the inline stat mod to anyone that monitors their UG temps more than the person sitting next to them.
I modeled my setup off ATL Disco's.
https://landroverforums.com/forum/di...tat-mod-48526/
Old Dec 13, 2015 | 08:40 AM
dgi 07's Avatar
Parts list?
Old Dec 13, 2015 | 08:46 AM
dr. mordo's Avatar
https://landroverforums.com/forum/di...16/#post185775
