Inoperative OBD2 port, Interior light and Power door locks all started working today.
Looking at the schematic might yield some results.
On the fold down access panel there is a diagram of the fuse locations. You can also search for this online. I'm not near my vehicle right now, but I think the right stack starts at #18 at the top, so #20 would be the third one down. I might be remembering this wrong so check the fuse layout diagram.
Also be sure to check your under hood fuse box. Look at FL3. On the front corner of the box closest to the fender there are three similar looking screwed down fuse links. The center one of these is FL3. I'd remove it, check continuity, and ensure that the connection is clean. Also check the power connections to this fuse box, as well as your ground cable connections to the body, just in front and below the box.
From what I found in a post on this forum, under hood FL3 feeds under dash fuses F1, F2, F20, F21.
bcolins (03-15-2019)
