Interior Door Handle Adjustment
Old Jul 17, 2018 | 08:57 AM
Bulax99's Avatar
Default Interior Door Handle Adjustment
I just replaced the driver’s side actuator and replaced the exterior handle door lock cylinder and got everything bolted back together. Everything worked great testing the function while the door panel was off and again when the panel was put back on. Quick note: I have superlock and the anti-theft system turned off in the BCU. I rarely use the door locks at all. This morning on my way to work I tested the power locks a few times. When I got to work The interior door handle wouldn’t open the door. I could roll the window down and open from the outside no problem. I tested the power locks a few more times and about a third of the time the interior door handle wouldn’t function properly. I have searched the forum a bit and couldn’t find an answer to whether the interior door handle cable could be adjusted. I thought I would throw it to y’all for input before I pulled the panel to check myself. Any ideas?
Old Jul 17, 2018 | 10:19 AM
redrover75's Avatar
I replace an acutuator a couple weeks ago. Door would not open at all. Now it does not open from the inside. Tested it okay, worked for a little bit. Its not the child lock.
I wonder if the internal wire came off? Will have to open it up again.
cornercase
Apr 26, 2022 08:17 AM
tboard24
Mar 24, 2015 12:36 AM
Rover_Hokie
Aug 19, 2014 10:05 PM
DiscoRom
Feb 27, 2009 02:07 PM
