Installed CDL in my 2003 Discovery
For those of you with the 2003 Discovery...and want CDL. It has been done.
http://picasaweb.google.com/jycsalas/AddingCDL#
and then enable the diff lock light
http://picasaweb.google.com/jycsalas...DiffLockLight#
Now i can run with the big boys...
Today must be my Birthday!
Did you have any issues with the new locking output housing? Same driveshaft (lenght)?. What was the green wire from the old non-locking housing? And did you have any concerns about the HDC (did you disable or just left it as is)? Sorry about the ?'s but I'm thinking about doing this to mine. Thanks!
On a 03, the neutral interlock switch is at the hi/lo assembly it's self, NOT on the t-case. If the transmission isn't in neutral, the shifter WONT allow you to engage into hi/lo. in my situation right now, those functions are independent from engaging the diff-lock. i can just get under the truck and lock the nipple by hand meaning i don't need the t-case in N to lock it.
Regarding HDC/tc... from the research i have done, the 03's were designed to "ignore" the diff lock input signal at the SLABS ecu which allows me to retain HDC/TC/abs WITH diff lock engaged...
read here for some more info on diff lock affecting HDC/TC/ABS
http://www.discovery2.co.uk/diff_lock.html
HEY EVERYONE!!!
I keep getting many requests for the CDL write-up!!! Keep them coming!!
And for those of you who want to know what I did as a shifter...
http://picasaweb.google.com/jycsalas/AddingCDLShifter#
I will start a separate thread on this so please wait until it's up so we can keep comments specific to the shifter over there...thanks.
