Installed drive shaft/strange vibration
Old Jun 12, 2008 | 07:10 PM
  #31
salve7's Avatar
Default RE: Installed drive shaft/strange vibration
I am going to have mine installed next week so hopefully I will have better luck. I have the summers off and I only have internet at work so I might not get to post an update until the end of the week, but I am trying to get it resolved.
Old Jun 22, 2008 | 09:09 PM
  #32
salve7's Avatar
Alright I finally got the thing fixed and now everything is running like butta. I no longer have any vibrations although I have not gone over 80 (I will probably never go that fast anyhow). So problem solved for me at least.
Old Nov 6, 2008 | 09:48 PM
  #33
mortality101's Avatar
What did you find was the problem finally?
Old Nov 21, 2010 | 08:18 PM
  #34
Second2None's Avatar
Exclamation Bringing this thread back to life
So the exact same thing happened to me. My '00 D2 needed a front driveshaft, I bought and put in a Tom Woods driveshaft, now have a vibration between 75-80mph. The rear driveshaft was removed too because I put in a transmission during this process and was put back back in (the original one).
Now, I'm confused with people saying the front driveshaft ZerKs need to be in the opposite line as the rear driveshaft Zerks... Doesn't each driveshaft spin at a different rate (unless the cdl is locked) and change they're positioning themselves when u drive the vehicle??
If I'm right then I must have missed what I'm supposed to be realigning and swapping 180 deg. Can someone explain to me? (Btw, as far as each driveshaft goes, all my zerks on each driveshaft are in line with each other)
DiscoJon
Jul 14, 2019 01:51 PM
MarkSF
Mar 8, 2014 03:23 PM
Snafu / Disco Fries
Mar 24, 2011 08:16 PM
SDinDS
Oct 4, 2010 02:24 PM
brooksa
Jun 6, 2008 09:34 PM
