Installed some driving lights
Old Oct 14, 2020 | 05:15 PM
Richard Gallant's Avatar
Default Installed some driving lights
After finding my Disco was setup for Aux driving light s following the BC standard (they only come on if the High beams are on). It was time to add lights.
I decided to go with the License plate light holder, there are a couple of issue with these on the stock as the license place holder is plastic. Not ideal for heavier lights, my solution is to add 3 braces, currently 1 installed. In the image below you can see the brace and the 2 Aurora 3w LED floodlights in test mod and the temp brace. In the end the braces will actually hold the bracket in place but I need to get my lighting sorted 1st.
Inside view, I will need to add a couple of more holes to support the inside.
Luck was with me and the connector on the lights was a standard connector, 5 minutes and some crimp on connector and I made up a Y harness that go the pods working. Next up was a spotlight, I went with a 7 inch LED spot /flood combo light, it has a bunch of other features but I need to tap into the Daytime running lights to activate those.
Here it is with all the lights mounted, I intend for the pods to be angled to the sides a bit to light the road edge.
And of course lit up
Parts list
License plate light holder License plate light holder
28.00 CDN
7 inch
Spot light Spot light
79.00 CDN (20.00 off for prime)
2 x Aurora POD lights free thanks to my brother
1 x H11 headlight extension for 7 Inch Spot light 15.00 CDN you need both ends the spot comes with bare wire and I had to replace the LR female connector
2 x 3408 male headlight connectors for the pod lights 15.00 CDN
1 pkg of male bullet connectors 3.00
1 pkg of female bullet connectors 3.00
With luck I can test and align everything this weekend, in the dark
Old Oct 14, 2020 | 06:12 PM
greisinb's Avatar
Interesting to hear about your car being “wired” for driving lights. I know the law is similar here in Washington, your aux driving lights can only be on with your high beams on.
Old Oct 14, 2020 | 06:16 PM
@greisinb I suspect the previous owner had an aftermarket bumper or bullbar and pulled it before selling. But the harness seems to LR, maybe the original LR bullbar.
DiscoBuckeye
Oct 28, 2019 10:10 AM
Discorama
Aug 28, 2019 03:56 PM
Tatonka82
Mar 25, 2014 03:58 PM
rappo999
Sep 5, 2013 07:47 PM
Street Wolf
Dec 19, 2008 06:04 AM
