Instruement Cluster
RE: Instruement Cluster
it will depend on the vehicle. in general it is from the interior of the vehicle. the best source is the manual for your vehicle. they are available on the net in both book and cd form. ebay is the least expensive that i have found for both. either way make sure you document the mileage change. and follow the directions. lay out you parts in the order in which they were taken out and when it comes time to replace them, there will be no questions. digital camera pictures are a good thing. hope it helps. gotta love a rover. duboff
This is what the cluster looks like removed
http://www.pix8.net/pro/pic.php?u=12864krk2I&i=585492
After you've undone the two screws at the bottom of the dash ( You can see them when the adjustable steering wheel is at it's lowest) (use a stubby phillips)
the dash hood unclips from the two steel fixing clips. Wiggle it back towards you and up a little Unclip the side switch harnesses. The hood then lifts off
For the instrument cluster undo two screws each side of the dash pod and lift dash pod up. Unclip harnesses and voila!
Langy
ps: Can anybody tell me the correct way to use the image function in this forum?
Langy
Greg
08-08-2007 04:47 AM
jdthmpsn
03-05-2007 10:58 PM
