Instruement Cluster
Old Aug 10, 2005 | 02:55 AM
psg's Avatar
psg
4wd High
Default Instruement Cluster
Anyone know how to get at the back of the cluster to access the bulbs? The hood over the cluster looks like it will pop off but I don't want to break anything trying if thats not the case . Disco 2 1999. Thanks
Old Aug 10, 2005 | 11:03 AM
duboff's Avatar
Default RE: Instruement Cluster
it will depend on the vehicle. in general it is from the interior of the vehicle. the best source is the manual for your vehicle. they are available on the net in both book and cd form. ebay is the least expensive that i have found for both. either way make sure you document the mileage change. and follow the directions. lay out you parts in the order in which they were taken out and when it comes time to replace them, there will be no questions. digital camera pictures are a good thing. hope it helps. gotta love a rover. duboff
Old Aug 10, 2005 | 04:27 PM
langy's Avatar
7th Gear
This is what the cluster looks like removed
http://www.pix8.net/pro/pic.php?u=12864krk2I&i=585492
After you've undone the two screws at the bottom of the dash ( You can see them when the adjustable steering wheel is at it's lowest) (use a stubby phillips)
the dash hood unclips from the two steel fixing clips. Wiggle it back towards you and up a little Unclip the side switch harnesses. The hood then lifts off
For the instrument cluster undo two screws each side of the dash pod and lift dash pod up. Unclip harnesses and voila!
Langy
ps: Can anybody tell me the correct way to use the image function in this forum?
Old Aug 11, 2005 | 11:42 AM
duboff's Avatar
thanks, never had to do it just had the book and now it is more clear than before. duboff
CandiMan
Oct 28, 2008 10:02 AM
underpsi
Sep 1, 2007 12:51 AM
Greg
Aug 8, 2007 04:47 AM
jdthmpsn
Mar 5, 2007 10:58 PM
lowill
Jan 12, 2007 11:17 AM
